Stroked and Blown
Hello
Has anybody here used the Chevy 2.8 head studs on the 96-98 3.8?
Several people over at SCCoA said they are a perfect match and even fit better than the 3.8 head studs, on the SC's though, which would be 89-95 model years (94-95 Mustangs also used this same block)
Some people over at V6power.net say the head studs are perfect on the earlier model 3.8's but not the 96-98 3.8's. Have any of you guys used the Chevy 2.8 head bolts on the 96-98 3.8's or do you have anyway of finding out if these will work or not?
I'm trying to clarify this for good so I can know if I should buy these or not.
Thanks
Stroked and Blown
Discussion Starter #2
Anybody at all? I'm pretty convinced the 2.8 Chevy head studs won't work on the 96-98 3.8's just from what I've read but I want to double check. I know there are SEVERAL V6 pros here, where you guys at?
I do not think they will work. Looking at pictures of the two sets, one from a 95-lower and one from a 96-higher, 4 of the headbolts from a 96-higher look to be much longer than ones from the 95-lower. That said it's probably safe to assume that the studs will be too short.
Confirmed V6 Nut
Blak,
Anyone say which studs ARE good for the 96 to 98 blocks? I've got a 97 block that I just want the throw the splitport setup on. If I can't find the right studs, I know a 95 motor I can buy, and I'll just throw everything on that and pray it works with me computer.
