hey man i have the book, chiltons it tells you everything you need to no. first the lower intake tighten the bolts starting in the center drivers side first than switch to middle pass. side for two and three is torward the back of the motor drivers side. 4 is forward of two toward front of the motor. 5 is in front of 1 and you follow this pattren till you run out of bolts. lol they all need to be snuged before you torque them down to 8ft lbs the first time, 15ft lbs the second and finally 24 ft lbs.
head studs i have no i dea but the nuts will need to be torqued to 37, 45, 52, 59 ft lbs. you start with the third bolt back in side the head. 2 is the second one back on the edge of the head. 3 is in front of 1 and 4 is behind 2. ok man i hope this helps. if not **** you. lol jk man. go buy a book at autozone or oriellys. or call me if you have ?s 716 909 3903 don
