I want to raise my headlights up slightly on my 1991 T-bird. I put some Ultra Silverstars in hoping that would solve the problem.
They are still to low. Probably from people slamming the hood before I obtained the car.
I looked in my service manual and it said a headlight aiming kit and adapter MUST be purchased to change the position of headlights. What ?
Is there a way for me to raise the headlights up slightly ? Every car I have ever had I was able to change the vertical or horizontal setting of the headlights.
I can do it on my 1991 Ford Mustang with no problem.
Thanks
To adjust your headlights you need to turn the stud that sticks through the support of the retainer connecting your headlights to the header panel.
I recommend this Headlight Adjusting Ratchet for Ford Headlights
Each headlight has 2 studs you can adjust, Left/Right and Up/Down. The stud closer to the inner parking lights or inner highbeams (depending on year) adjusts your Up/Down motion. The studs closer to the outer corner signal lights adjust the Left/Right motion.
Here is what you need to do to aim them Up/Down:
•To aim the headlight beam higher turn the stud clockwise.
•To aim the headlight beam lower turn the stud counter-clockwise.
Here is what you need to do to aim them Left/Right:
•To aim the headlight beam towards the center of the car turn the stud clockwise
•To aim the headlight beam away from the center of the car turn the stud counter-clockwise
1) At night, park the car on a flat surface facing a wall about 10' away. Turn headlights on (LOL).
2) Find the distinct centerline in the headlight beams on the wall. This is created by the design of our headlamps/bulbs.
3) Correctly adjusted, the centerline should be about 26" from the ground, against the wall.
4) Beams should stay fairly much within the left/right fender lines. In other words, the beams shouldn't be spreading out so far that, if you were in the center lane of a 3 lane road, the beams should not cross over the left/right lanes of the center lane you're in.
5) When correctly adjusted, at about 30-40' away from the wall, both headlight beams should converge into one beam.
Need more info..Check out this Sticky-->>How To Adjust Your Headlights
You are the BEST !!! Thank you so much for this information. I don't understand why my service manuals which includes Chilton, Hayes, and Ford Factory Shop Manual did NOT show this.
Will aim this weekend and give you an update.
Thanks again.
