My highbeam light on the dash is stuck on when I turn on the auto-lights or the switch. I'm not to sure where to start mostly because the lights don't come on. Just the headlights the corner and tails lights are on. I wanted to know if someone knew what causes the indicator light on the dash to stay stuck on. Odlly enough thought when I have the lights off and the press the high beam switch in the lights don't come on either, but the indicator light does come on. I wonder if it's a relay or a fuse. I check the lights and they looked good. Any ideas would be great help. Thanks
I would look at the multifunction switch first. More than likely that is your problem and it's easy to change. After you check your fuses and relays
