I am having problems with my head lights. When I turn them on, after about 2 or 3 minutes they start to turn off and on. Only my Hi beams stay on if i hold them on. I have to drive around with me hi beams whenever it happens it sucks. I have no idea what is causing this can somebody please help me, thanks in advance BTW, Its a 91 CougarLS 3.8
check the wiring harness behind the lights, i was having the same problem, it turned out that when the bulbs heated up it was backing the connection off because they were starting to short out and melt, if the harnesses look like new then you dont have my problem though
in the end the harnesses were only like $3 from my ford dealer here in ohio
GOOD LUCK!!!
Dim Bulb
Sounds like the multi function switch... blinkers, high beam selector, wiper control, that doohickey
