Hey folks!
As the title suggests, the headlights on my 97 won't come on but the brights work like they're supposed to. Thoughts? Thanks!
Most likely, if it's not a fuse, the switch has a burned contact.
Could be the dash switch, or the MFS, which has pull-to-pass highbeams.
Try another bulb? Doubtful both went at the same but, just a thought! :tongue:
So, the high beams went out as well. I've replaced the Multi Function Switch and still, neither the high beams or the regular headlights work. I will be swapping in new bulbs in the morning.
Out of curiosity, where is fuse for the headlights located? Thanks!
#7 under the hood.
It's a circuit breaker on the light switch, save for the "Flash to Pass", which is the cigar lighter fuse (20A).
