Ok, here's my dumb question. I have a 91 cougar with a headlight problem. The other night coming home from work my headlights shut off and would come back on while driving ( made for an interesting ride home). For the first 10 minutes, they worked fine. The they started going on and off, at the same time I noticed that the indicator light for the autolights was going on and off with the headlights. So, I disconnected the auto light module. this did not help. I flipped the lights to high beam and they would stay on a little bit longer but still would go on and off. While on high beam, the high beam indicator would go out with the lights. And to beat all, if I pulled back the dimmer to passing lights, the high beams would stay on, but the low side would still go on and off. I don't think it is the headlight switch. I'm thinking that it is either the mutlifunction switch in the column or a grounding issue. If anyone can lend me some ideas, I would greatly appreciate it. Also, the first night that this happened, it was raining. But, it did it to me again tonight with no rain. I know that it wasn't a water issue. Wasn't sure on that side of it is why a chanced it again tonight. Hopefully, someone else has seen this and can enlighten me. Thanks in advance.
I would guess a bad MFS switch a very common problem on this car... you can get them from advance autoparts or from Ford I got mine from 93LX (he works for Ford)
motor city poster
i know there is a problem with the headlight switches in the eariler t-birds, i had a 90 and it turns out the headlamps draw too much current for the stock switch, so maybe you could look into that,
My '97 does this on the rare occasion. On mine, if I turn the switch off and on, they come right back on. It hasn't happened enough to detect any kind of pattern, and I don't feel like throwing parts at it. Post up your solution if you get it fixed.
Mine did the same thing. It was the headlight switch. It was between 15-20.00 at Advance. I usually drive with my fog lamps on at night, which draws some extra current through it and wears it out even faster.
Got em fixed!!
Thanks for the help. I swapped out the headlight switch over the weekend. They are working fine again. It was a little more than $15 bucks, but I also have the autolights. The switch wound up costing me $25. Wich is considerably cheaper than the $145 they want for the MFS. Thanks again for the help.
