Hey All,
Well, after a short drive attempting to home, someone was kind enough to point out that the headlights on my bird weren't on any more. I got back to the shop and sure enough, no headlights.
What happens:
The Hazard flashers work, turn signals do not.
Dimmer works inside on the dash.
Interior lights and underhood light works.
If I pull back on the switch for high beams, they do turn on, but pushing forward on the switch does not yield the same result, does not even register on the dash with the highbeam indicator.
Brake lights work, reverse lights work.
Here's what I have done so far:
Checked all fuses, none were blown
checked the bulbs, no burns, filaments totally intact.
Checked the highvoltage fuse, even swapped it with another 60Amp to make sure.
Banged my head against the wall while trying to surf through all of the posts about smoked headlights and FS postings while trying to find any information.
What I have found and what I think it could be:
MultiFunction Switch?
Light Switch
Gremlins.
Any ideas to narrow it down? I can't afford to go throw a ton of money at this problem, so what is the most likely culprit?
-Will
96 Thunderbird 4.6L
89 LeBaron 2.5L
What happens:
Light Switch
Gremlins.
-Will
96 Thunderbird 4.6L
89 LeBaron 2.5L
