1 - 11 of 11 Posts
Quick question, I want to separate the lens from the main piece of my headlights to clean the inside. Would a heat gun work, or are we talking about ALOT more heat like an oven for a small amount of time.
Raoul Duke
I got mine apart by running them under hot water for a few minutes. This also helps to clean and flush the dust out from inside the lamp.
Well, I had an extra driver side headlight, so I put that one on. I still CANNOT get the lense apart on the headlight I took off the car.
I'm about to the point to take a hammer.
the insides of the headlights do NOT yellow. i know this since i have taken apart and cleaned many headlights. i dont use any heat at all. the coug lights are tough to get apart. i happen to have a clear set of coug lights for sale. lemme know.
yes, these will fit on a 95. i will need your old headlights anyways to continue my business. thats how it works :) i charge $60 plus shipping (usually around $10), and you send me your old lights in the box when you receive my clear ones.
those clear 'nuff for ya? :D
Mine cleaned up real good on the outside, but they seem to have cracks(spiderweb looking) on the inside. Have you run accross this or did I not sand the outside good enough?
Rob
big mike said:
nope, sure havent. i have never sanded. try using a finer grit sandpaper. are you sure the cracks are on the inside?
I used the tech article method of using finer and finer sandpaper, then move on to 0000 steel wool, then the polish.
I have also used the maguires plastic polish.
I'll have to do more inspection, but the outside feels smooth, so I thought it was probably on the inside of the lense.
Rob
1 - 11 of 11 Posts
