· Registered
headlights
I don't know about those bulbs, but if you want more light it's not that hard a job. Best thing I've done to my '91--now I've got all 4 lights on high beam, and I use 80 watt lamps for the lows and 100 watt for the highs. That's 360 watts total as opposed to the original 120 or so on high beam.
· Registered
That smoke coming from the front of your car is the plastic lense covers melting ;)
How did you get all four lights on highbeam?
· Registered
I haven't had any overheating problems, but I read it was because the engineers were concerned about melting the plastic lenses that some T-Birds, Camaros, etc. have such weak headlighting. Even in the late 50's, all four lights came on when you hit the high beams. If you want to re-do it to get more light, I can give you the whole rundown. It's not all that bad a job.
· Registered
You can buy a harness to make all 4 lights s tay on or you can make your own harness, on the front page you can go to most wanted parts and go down to the competition-limited lights and click that link, iirc, its about $80 for it.
You might be able to get away with using the kit that summit sells for chevy trucks, you will prob have to do some cutting/soldering(I wouldn't splice and tape).
There is also another guy that uses high quality relays and what not and builds them on a per application basis.
There also may be something in the tech articles about it.
I would def upgrade the wiring and use relays.
