1 - 20 of 26 Posts
This is the 4th time this has happened to me. I will drive the car for weeks maybe even a month and then just out of nowhere it doesn't start. The starter solenoid clicks and thats about it. The first time it happened, I tried to get a jump and that didn't work. I still get power to everything in the car and the headlights don't dim when I start it. The second and third time I just let the car sit and then it started after a day or two days. I took it to autozone so they could test the battery and the alternator and they said that the battery was kind of low but the alternator was fine. I drove it for 7 hours to DE and had it tested again and everything was fine. I was able to drive back from DE to NC and then I drove for a month after that. The next thing that I am thinking it could be is the starter but I'm not 100% sure. Anybody got any ideas?
It could also be your wires. That happened to me. I had an old battery and the positive wire termial on it started to collect battery acid. I cleaned it off and thought nothing of it. Threw in a new Optima and ran into similar problems. Turns out the battery acid also seeped into the wires and created resistance.
I had thought about that also. Coincidently it is raining bad here. The first time it happened it was kinda cold outside, the second time it was right after it snowed. Now its raining. But now where are the wires routed, the car is sitting in the parking lot of a bank so I can't really do an in depth search for them, but I can do my best.
Before you get to in depth clean the battery terminals, possibly replace the terminal connections.
Ok, I will do that, I was planning on replacing the Big 3 like I read in the audio/electronics forum (i think) so I will just go ahead and clean and replace the terminals. They look bad anyway, I tried to clean them with a wire brush but I'll just go ahead and replace them.
Cables come with new terminals, and its better insurance.
He said his car is stuck in a lot. The terminals will be the easiest for him to deal with given his situation. Running new wires would be a ****ty job in a parking lot.
Terminals are three bucks each and easy to change. Id go that route first.
Well I went back to get the car and decided hey it doesn't hurt if I try at least one more time. So I turned the key and it clicked once and the started, easily. I put on new terminals and figured I would be ok for at least a little until I got to do the wires. I went outside at about 5 in the morning to go to work, and I get nothing. It clicks, but no start. Is there supposed to be a splash guard or any type of shield near the starter, becuase there is isn't on my car and its rusted like a ***** down there. I'm thinking thats where my bad connection is so thats what I'm taking a look at next, as soon as it gets a little lighter around here.
Just a splash gaurd over the wires connecting to the starter.
You have a bad connection somewhere. I think your on the right track. At least you are out of the lot now.
Yea, its just freezing down here now, it was 35 deg. this morning. I have to work all day tomorrow too, I won't get to take a look until at least Monday. I'll let you know what happens then. Thanks alot for your help though. After I fix the problem I'm going to try and make a better guard for the starter and starter wires.
freakin 35 degrees?!?! If its above freezing it's warm buddy! It's 0* here! BE A MAN :D
-Thomas
Are you complaining Thomas? Im farther north than you. NO chance Im going outside today....but I do have a heated garage.
change the starter, mine did the same thing until I changed the starter. takes about 15 minutes to change and its under 100$ for a reman. Mine would click every once in a while then if progressivly got worse over a few 1000 miles until I changed it. usually tapping the starter with a hammer would make it start.
Discussion Starter #15
I wish I had a heated garage. I live in an apartment, all the work has to be done in the parking lot at high noon, or at least before 3. Thats when its warmest around here. lol Oh and yeah, I'm trying to be a man about it, but I would rather be warm in the process. :D
today here, high of 10* low of -6* and I'm replacing a local guys fuel rail in his apartment garage but the front of the car will be pointing towards the door because there's no lights in the garage. Yay hehe.
Discussion Starter #18
Is it windy? lol. It is down here, wind chill is about 16*. I don't mind the cold at all, it feels good sometimes but the wind is ridiculous.
Really quick today I went out to take a look at the starter. I jacked the car up and found what was probably the most heart wrenching sight. The starter bolts were stripped :redmad: NEVER buy a car from an auction, you never know what your going to run into. Apparently someone tried to remove it and stripped the bolts and now I get stuck with it.
I saw something in Autozone once, it was like a socket that had teeth in it. Do you think that will loosen the bolts up. I don't to give my car to the mechanics around here, they always find something wrong with the car that has nothing to do with the original problem. I did my mom a favor once and had the starter to her car changed at the dealer and when I got it back, the cigarette lighter was somehow ripped out the dashboard and they wouldn't take any responsibilty for it.
Discussion Starter #19
Ok, for those that may be interested. I went out today and took a look at the starter. I'm not sure what to call it but there are three wires at the starter. Two 8 gauge and one 16? gauge wire. Well the smaller wire was worn to pieces. Water had gotten up there and corroded the wire to the point where the connector snapped when I tried to take it off. So I went up to autozone and got some new wire and connectors and wired it all up and now she runs once again. Its a beautiful thing to hear a car start. :D :D :D Thanks for everyones input, I really appreciate it.
All the cars I have ever owned have been Fords. I can honestly say, everytime the car or truck didn't start, it always led me to the starter. It has been SO consistent, that I don't even bother with cables, or batteries......I always head straight for the starter.
Glad to hear it's running again. Nothing is worse then having a good running vehicle not start in weather like this because of some botched up connections.
Skip
1 - 20 of 26 Posts
