So, my radiator fan is not working. Would this make my motor overheat? Is there a fuse or anything that could be causing it not to work? If not, I am stuck buying a new one huh?
Pappy
The power for the fan comes from a relay assem.
If the A/C is the fan is suppose to come on.
Without A/C low speed is 205 deg. and high speed is 230 deg.
If the fan doesn't come on check voltage at connector to fan.
My motor would come on if you gave it a push start. Replaced the fan,
Works great
Francis
Sigh.... So, I go out and I buy a new Fan Assembly, Water Pump, T-Stat, and have the radiator hot tanked and rodded. Total cost = $325.99
What fixed the problem? A $2.99 fuse in the main relay box......:bawling: :zraped:
