so just take it out it will be fine, thanks for the quick response.LOL Yes, it is the plug that is put into the end of the fill/dipstick tube at the time of manufacture. Its designed to pop out when the dipstick is inserted and just ride out its days drifting in your tranny pan. If its there, its a safe bet that the transmission has never been opened up prior to your opening it.
Feel free to discard it.
is that good or bad news?If its there, its a safe bet that the transmission has never been opened up prior to your opening it.
depends, if its got more then say 50k on it probably bad or at least not that great.is that good or bad news?![]()
My car has 175xxx on it tranny is clean, i got the car in 04 with 116xxx so i thought it was about time to do the trans filter i did a flush last year. Trans doesnt feel like a slush box no moredepends, if its got more then say 50k on it probably bad or at least not that great.
Or the fluid was changed Jiffy Lube style, with the vacuum pump thing.Well, it might not mean the fluid has never been changed. It just might mean that whoever changed it before found the thing floating around and thought, "You know, I don't want to mess anything up so since the trans was working before, I'll leave it in."
Lol, I remember being trained on those....T-Tech is what it was called. Just make sure you dont look into flushing it just to be safe, since you found that piece in there.Or the fluid was changed Jiffy Lube style, with the vacuum pump thing.
Thats where i flushed it, I was a proud member of the j-team for a year and a halfOr the fluid was changed Jiffy Lube style, with the vacuum pump thing.
