I was putting a new stereo that i got yesterday (monday) and when i "finished" the stereo did not worked.... So when i wanted to get my car out of the garage several things were wrong...... :
1.- When i pushed the brake pedal, the light would not turn in.
2.- The emegercy light would not turn in....
3.- I would not change gears.......
I cheked all of the fuses and they are all ok...... What wrong... PLease HELP.. HELP....
Does anything work??
I mean, does the car start?
Have you really checked all the fuses?
Both under the dash and the hood??
'Cause all those things you just mentioned should have
constant power i.e. should/could be on the same fuse...
The other thing you could do is to remove the stereo and check again...
Still nothing.... ?
A fuse...
Working?
Something not connected right into the stereo..
Check every cable and make sure you're connecting everything where
it should be...
That's the only thing to do....
Reg's
//Per A
yeah they are all hot
all the fuses are hot under the dash (which fuses under the hood?)
The car works fine, everything works except for:
1) hazard lights
2) shifting, even with brake depressed.
3) power seat
4) rear lights dont light up with brake pressed.
Its weird, really weird.
The power distribution box
There are fuses under the hood that SHOULD be in the general vicinity of the battery. Sometimes if the 5 amp memory fuse is blown, you loose the stereo, as i learned.
If this helps, good. But if it doesn't, i can't help you further.
