Sooo once you take apart a car by yourself over the period of 2 years to tend to forget where things go back in place. For those MN12 part pros help me puzzle back these pieces and I’ll give you a internet cookie. Thanks in advice for your help.
Part(s) 1: Ok I'm not sure, but are these the starter or ground cable holders? They are attached to the engine block?
Part 2: My wild guess, trans cable bracket??? :confused:
Part 3 & 4: Ok both of these parts were toward the rear end of the car's underbody. Part 3 looks like a drawer handle to me, lol. Part 4 looks like it's for the exhaust heat shield.
1: bracket on the right is the powersteering line/swivel support bracket.
2: gray transmission main harness bracket, located near the tailshaft/vibration insolator.
3: driveshaft safety loop bracket.
4: shield between driveshaft and gas tank.
I could be wrong and I'm sure that's none of the proper names, but I hope that's helpful.
First picture item on the left is for the power steering line iirc
3 & 4 mount in the driveshaft tunnel. IIRC the loop one is behind the tank, the sheet metal one is ahead of it
So for part(s) 1: Would you say those are from the long odd steering hose? I did Matt's -AN conversion mod so I suppose those are from the old line.
Part 2: I had a feeling that was the trans bracket, I was under the car today knowing there was some sort of bracket that tied in the shifter cable.
Part 3 & 4: I already bolted up the gas tank, I hope I won't have a problem getting around putting those back in. :eek:
Awesome thank you.
For rmfk13, Chris_Murder and XR7-4.6 you get freshly baked internet cookies. :)
For guitar maestro you get burnt internet cookies, sorry bro. :tongue:
