1 - 12 of 12 Posts
hello all, can someone do a short write up on how to remove the inner tie rod.
i am replacing both the inner and outer TR.
thank you much
thank you for the replies....and sorry i did forget to use the search funtion.
i am replacing the outer & inner, the UCA & the LCA and the sway bar link. Once all this is done, definitely needs an alignment.
oh no!!!! there is a rivet insert in there.
i was able to remove the boot and saw a rivet insert
how do i remove it? and what size wrench do i need for that inner tie rod?
thanks again
+1 Forget you saw the rivet and spin it right off with a big crescent wrench. The rivet is aluminum and won't damage the threads at all.
1 - 12 of 12 Posts
