Hello everyone
I have found a Eaton Supercharger Model 112 from a SVT Cobra.
Can this work on my T-Bird 94 with 4,6L engine?
What can i need more if this can work?
No, it will not work with your stock heads.
You need the Cobra's DOHC heads, intake, and upper plenum to use the M112.
Sorry, mate.
It could possibly work, but it would involve a major amount of aluminum fabrication/welding. Plus the 94 heads are the worst 4.6L heads out there being very restrictive. :(
Since you have the 94 with the aluminum intake, you basically cut a hole in the top of the manifold and then weld a plate onto it to match the supercharger outlet. There's a LOT of fabrication work, but mainly just aluminum milling, grinding and welding.
I'm even pretty sure someone on here already did something like that years ago. I just can't remember who; Frankencougie maybe?
But just my opinion but on a stock early 4.6L, I don’t think the gains would be worth the fabrication nightmare.
