Help. My 97 Lincoln Mark 8 is throwing some codes. The scanner has a general description of the sensor but not sure about thier location.
The codes are:
P0133 - o2 sensor bank 1 sensor 1.
P1131 - manufacturer control air/metering device
Any help would be greatly appreciated
Thanks. Where might I find the air metering sensor and which bank is bank one the driver or passenger side of the car? How are the sensors positioned? Is the first sensor twords the front of the car or twords the fire wall?
The code description is too generic and not accurate. The "air metering device" is the oxygen sensor, and both codes refer to the same sensor. The sensor in question is in the exhaust in front of the catalytic converter on the passenger's side of the engine. Look at the exhaust starting from the engine and the first sensor you see in the exhaust pipe is the one.
