1 - 2 of 2 Posts
I have a reaccuring P0302 code (cylinder 2 missfire) I changed plug and wire it comes back after a few hundred miles I also have a P0430(catalist below threshold) and a P0133 (O2 bank 1 sensor 1 )please help I need to get CEL to go out so it will pass inspection thaks
Russell
something i ended up doing on my roomys 94 lx was i ended up changing the d/s coil pack. i was getting the same codes but the first was a p0308.
fixed the problem of the 02 sensor code also. pull the #2 plug after running it. if theres unburnt fuel/plug is shiny with gas, that may fix it.
hope this helps
1 - 2 of 2 Posts
