Hey guys, I will fully admit, I'm not the best when it comes to wiring. So I need some help.
In this picture, I need help with the Blunt Lead 1. I need to connect the Red/Light Green Wire to the Ignition Switch Position.
Second, on Blunt Lead 3. I need to connect the Red/Light Blue wire to the start node of the ignition to switch.
(*If non-PCM controlled starting is used, step 8.2 C may be omitted, and unused blunt leads should be cut to ~2”
length and sealed using heat shrink.)
I have a Ford Electrical manual, I took a picture of the ignition switch diagram.
Let me know what you guys think,
Josh
Josh
