For a while now, my car has been making a squealing noise in more than one way.
1) When I turn the wheel, either way.
2) If I push the front of the car up and down, it makes the same noise.
I have the tires pulled off right now, both sides of the car jacked up, and had someone turn the wheel while I checked out th situation, and with them pulled off, it turns as smooth as could be. I am going to try putting the wheels back on, and keep it lifted, to see what happens. I will post a link to a vid afterwards to you guys can visually see/hear what I am talking about.
I have taken it to 2 different shops, both said that the only problem they see with the front suspension is that my inner tie rod on the drivers side has a little play in it, and that the upper/lower control arms/ball joints were still good.
Discussion Starter #2
Here is a vid of what I'm talking about, the first parts is the wheels turning form side to side, for about the first 30 seconds, and the rest I had someone push up and down on the car to show how it makes the same noise then.
Sounds like ball joints to me...
Damn. Last time I heard that sound, it was on my 1967 Mustang (was the upper control arm bushings shot - a common problem in that Wannabe-MacPherson-Strut design Ford used ... )
Upper control arms and I'd do the lower in case the lower ball joint is going bad also.
