i replaced intake manifold checked all vacuums, engine idels fine but when you
push thr gas it runs rough.
icouldreally need some help
is there any coolant in the plug holes, take an air compressor and pull out the plug wires and blow in them, that is a comon quick problem that it could be, if it doesnt wix it sorry wait for other ideas
It doesn't run rough at an idle????Check all vacuum lines and look for a leak.Use a spray bottle to check them.
Define rough. Does it fell like it's missing under load? If so, one of the plug wires may not be completely seated. It's happened to me before.
Peter M
