1 - 11 of 11 Posts
Sealed envelope - Put in the freezer for a few hours, then slide a knife under the flap. The envelope can then be resealed.(hmmmmmm...)
For icy door steps in freezing temperatures: get warm water and put Dawn dishwashing liquid in it. Pour it all over the steps. They won't refreeze. (Wish I had known this for the last 40 years!)
Crayon marks on walls? This worked wonderfully! A damp rag, dipped in baking soda. Comes off with little effort (elbow grease that is!).
Permanent marker on appliances/counter tops (like store receipt BLUE!) Rubbing alcohol on paper towel.
Whenever I purchase a box of S.O.S. Pads, I immediately take a pair of scissors and cut each pad into halves. After using, place S.O.S. in a zip lock bag, seal and place in the freezer of your fridge until it is needed again. After years of having to throw away rusted and unused and smelly pads, I finally decided that this would be much more economical. And now a box of S.O.S. pads lasts indefinitely!
Blood stains on clothes? Not to worry! Just pour a little Hydrogen peroxide on a cloth and proceed to wipe off every drop of blood. Works every time! Now, where to put the body?
Use vertical strokes when washing windows outside and horizontal for inside windows. This way you can tell which side has the streaks. Straight vinegar will get outside windows really clean. Don't wash windows on a sunny day. They will dry too quickly and will probably streak.
Spray a bit of perfume on the light bulb in any room to create a lovely light scent in each room when the light is turned on.
Place fabric softener sheets in dresser drawers and your clothes will smell freshly washed for weeks to come. You can also do this with towels and linen.
Candles will last a lot longer if placed in the freezer for at least 3 hours prior to burning.
To clean artificial flowers pour some salt into a paper bag and add the flowers. Shake vigorously as the salt will absorb all the dust and dirt and leave your artificial flowers looking like new! Works like a Charm!
To easily remove burnt on food from your skillet, simply add a drop or two of dish soap and enough water to cover bottom of pan, and bring to a boil on stovetop.
Spray your TUPPERWARE with nonstick cooking spray before pouring in tomato based sauces and there won't be any stains.
Wrap celery in aluminum foil when putting in the refrigerator and it will keep for weeks.
When boiling corn on the cob, add a pinch of sugar to help bring out the corn's natural sweetness.
Cure for headaches: Take a lime, cut it in half and rub it on your forehead. The throbbing will go away.
Don't throw out all that leftover wine: Freeze into ice cubes for future use in casseroles and sauces.
To get rid of itch from mosquito bites, try applying soap on the area. And you will experience instant relief.
Ants, ants, ants everywhere ... Well, they are said to never cross a chalk line. So get your chalk out and draw a line on the floor or wherever ants tend to march. See for yourself.
Use air-freshener to clean mirrors. It does a good job and better still, leaves a lovely smell to the shine.
When you get a splinter, reach for the scotch tape before resorting to tweezers or a needle Simply put the scotch tape over the splinter, then pull it off. Scotch tape removes most splinters painlessly and easily.
Now look what you can do with Alka Seltzer. Clean a toilet. Drop in two Alka Seltzer tablets, wait twenty minutes, brush and flush. The citric acid and effervescent action clean vitreous China.
Clean a vase. To remove a stain from the bottom of a glass vase or cruet, fill with water and drop in two Alka Seltzer tablets.
Polish jewelry. Drop two Alka Seltzer tablets into a glass of water and immerse the jewelry for two minutes.
Clean a thermos bottle. Fill the bottle with water, drop in four Alka Seltzer tablets, and let soak for an hour (or longer, if necessary).
Unclog a drain. Clear the sink drain by dropping three Alka Seltzer Tablets down the drain followed by a cup of Heinz White Vinegar. Wait a few minutes, then run the hot water.
Please be very careful with this. They won't refreeze it's true, but they will still be slick from having soap on the surface. They used a salt/soap mixture for our one day of snow this year at work and the parking lot is still covered in spots of soap, especially the exit to the road, I'm always kicking the rear-end of the car out now trying to get out of work.
Anything But Typical
Just watch doing this on dark colored clothes. Peroxide does have a mild bleaching effect, and leaving it on too long can make it fairly noticeable.
--Molly
I got it in an e-mail from one of my friends and decided it might help. Thanks for adding some actual trial results. :thumbsup:
Fry Rice Specialist
also try using newspaper to clean glass. cleaner and shinier than you expected. based from personal experience.
Full Metal
wow, most of this stuff actually works, lol....:D
1 - 11 of 11 Posts
