1 - 11 of 11 Posts
ok im about to order some high flow cats from www.supercoupeperformance.com, now they give me 3 sizes
1. 2"
2. 2"1/4
3. 2"1/2
now which ones should i get or will fit, i dont know the size of the exhaust tubes, these are the bullit style high flow cats, thanks for the help
Marvin M.
It should be 2" pipe coming off the manifolds. I would check with the shop that's going to install them and see what they think, maybe you can go with a slightly larger diameter. I looked into the cats a while ago and was told they're not exact replacements, you'll need a shop to do some work to get them on.
yeah i know the shop will have to cut my stock gutted cats off and weld the high flow ones on, i dont know if its going to be a lot of work though.
Marvin M.
well ive lost some low end torque, plus im running glasspacks and they dont help much with the torque either, im thinking on going to the flowmaster cat-back or two flowmaster 40's.
Marvin M.
That makes sense then. I have my cats gutted up front and have a high flow cat following them. It then duals off to 2 flowmaster 40's.
94onair, do you have a pic you can share of your cats????? does it matter were you put the high flow cats, as long as its in the same spot were the stock cats used to be????
Marvin M.
Marvin,
When I checked them out they told me the new ones would have to be further down, definitely not in the stock locale.
Do NOT buy those high-flow cats from scperformance. I don't mean to hurt their business, but seriously-- the worst purchase I've made for my car was a used par of those cats (had like 4k miles on them, I think) I got from a guy on sccoa. It only took a little while for me to figure out why they were being sold. The bricks inside don't have enough support (I wish I had a picture). They rattle (loudly) and eat themselves up. Eventually, they completely dissintegrate, and voila! Gutted cats. It only took mine 2 weeks. I had to shell out another 400 bucks for new cats. What a waste of my money.
PJ
PJ,
What did you end up buying then, new stockers or are there other aftermarkets? Thanks. :D
Since what I got was the SCP downtubes with the high-flow cats on them, I just told my exhaust guy to find something small enough with the same diameter. He didn't have many options but I don't know what brand he put on. It's pretty generic. You know, if you look at catalytic converter design, there isn't much that can be improved. The SCP ones tried by reducing internal bracing, but they sacrificed longevity. If it helps at all, I bought a cat-co replacement cat pipe for my RX-7, and I am extremely satsified. It helped me pass emissions and weighed a TON less than the stockers. I'd try their stuff. Check Summit.
PJ
1 - 11 of 11 Posts
