Just primed and checked my oil pressure before the engine goes in and got 75PSI (using a 18V BD drill), is this ok or may the rod be too tight, I check all the main and they were .001 to .0015 (by plastigage), rods were .001 or less real hard too tell.
93 SC
Every thing has been replaced.
Discussion Starter #2
Recheck all the bearings and all clearances are .001-.0015.
Is is safe to assume this is my new normal?
Clueless Poster
when i first start my car up when its cold the psi is 75 then lowers down quite a bit. at a red light it'll be as low as 20psi
Makes me feel a bit better considering how low 4.6s oil pressure is supposed to be stock.
Clueless Poster
yeah mine drops way down once its warmed up and everything
Well the 3.8 has the highest pressure @40-60, with the 5.0 just about the same and the 4.6 is 22-40.
