... (and after SEARCHING,and looking in my Chilton's,)......but not from the door, but "door frame", where it's attached to the car. I was at a u pull it today browsing, and i yanked one from a 95. To remove it I had to bend the fender to get to the 2 bolts. Can I get to the bolts without bending my fender or am i going to have to remove my fender? Any tricks to this trade? TIA
Open the door and you can get to all of them from the interior side of the door. You have to remove some interior stuff to hold the nuts on the inside.
you can't unbolt 2 of the 3 bolts from the inside of the car. Is fender removal the only other option?
:zbash: Only AFTER removing my fender did I notice that you can remove the 2 outer bolts by removing the power antenna. That gives you enough room for a 13mm wrench.
