Resident Line Creator
I have two issues to discuss in this thread.
1. I notice when it gets a little chilly in the morning, my front end makes a little bit of noise. This noise occurs when I go over bumps and sometimes when I'm not even going over bumps. Its like a hollow knocking or tapping from the drivers side. I don't know what it is.
2. I have noticed that when I apply the breaks at a high rate of speed or just hard in general, my car pulls to the left. We just got new front brakes and rotors about a month ago. This was actually doing this before we changed the brakes and rotors so I am a little confused.
Any help on these topics would be greatly appreciated. Thanks.
1 is probably sway bar end links.
2 could be ball joints (upper or lower) or tie rods.
Bottom line, time to check your suspension for wear.
I had the same problem with pulling, but to the right. After replacing the calipers, it turned out to be the strut rod bushings at the control arm.
