So my horn is not working. Fuse is good, relay is fine and is clicking when 12 volts applied. The relay is getting 12 volts and is hot all the time. I had to replace the clock spring since I accidentally turned the steering wheel over too many times. Derp.
I don't have the PCM, cruise control did a coyote swap. Not sure if it is linked together.
Any ideas?
Discussion Starter #2
Ok I fixed it. I plugged the cruise control servo back in. I guess they are connected. I'll have to figure out which wires I can tap into each other to make the loop back to the steering wheel.
So here is the wiring diagram of the horn / cruise. What wires would I tap together to bypass the cruise servo?
haha never mind I guess I don't need help. If you ever want to bypass your cruise control and you need your horn, you have to tap the Black (Ground), Light Blue/Black (Control Switch Imput) and the Dark Green/Orange (Control Switch Return) all together.
Epic thread of the day! LOL
Pose a question then fix it yourself. :D There's nothing like talking yourself through a problem.
Anyway, glad you got it working. Congrats on troubleshooting it yourself.
X2!
Time for a cold one Josh! :zbeer: :D
Cold beer of the day, Liquid Aloha - Longboard by Kona Brewery
