1 - 12 of 12 Posts
Ok I am in my car after I am riding it for a while and I get off in the drivers side the car is real hot but this is just under the drivers side. What can it be? The dealer said they fixed it but it is still there it is like right under the door. Can it be the exhaust?
Might be the Cat on that side :confused: Plugged up - any strange smells
or perfromance loss ??
Not any smells but the car sometimes stuttters and most of the time the temp of the car goes a bit a bove the midline
Ayctually it was when I bought it like 3 years ago already the had said they fixed it because the had it at the shop for like 3 days before we bought it. Theydidn't give us any reciept or anything. I guess they fixed the bassenger side because it would do the same thing
LST MN-12 said:
Might be the Cat on that side :confused: Plugged up...
If it's plugged up, can he look under there and see it glowing?
It sounds like a plugged cat to me also.
Rob
Resident Gun Guru
I agree girdnerg, plugged cat.......inner wall colapsed...............most likely glowing red ;)
veyito_169 said:
Ill lokk at it the next ride around to see if it is red
It may not turn red all the time if there is loose particles
inside the cat - Are you able to work on your car ??
If so you can pull the Y-Pipe off and using a large shop vac
blow threw each header pipe while plugging up the other
and determine the flow volume that way :cool:
Post in the wanted forum for a used Y-Pipe assembly
might get one CHEAP :D -
1 - 12 of 12 Posts
