COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,200-6,200 RPM
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 224 int./232 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 282
Advertised Duration: 274 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.555 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.565 in.
Valve Lift with Factory Rocker Arm Ratio: 0.555 int./0.565 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: FW XE274HR-12
