hello group,
i found out that someone at some point replaced the rear end in my car, and i can thank them for that, cause it is trac-loc , leaves 2 nice black marks on dry pavement. my car is automatic trans. is there a way to tell if its a 3.08 ,3.27 gear etc. i have checked my rpm's at these speeds, this is what i get in overdrive....
55 mph= 1400 rpm's
65 mph= 1700 rpm's
thanks for any help
Frank
Rodeo Joe said:
I haven't checked it at 65 but at 70 mph mine is at 2K RPM with a 3.27 rear gear.
i checked mine at 2000rpm's = 75mph
Mine is at 2,000 at 70 MPH. but I may not have gotten the needle back on right when I put the gauge faces on. In that respect I'd like to know what a stone factory 97 3.8 turns at 70MPH. Did I get the needle on right?
Formerly Fdawg97LX
if you have a stock rear end in there you can also check your axle code on the sticker in your door jam. its the nmber/letter listed onder AX. once you get the code match it up here .
Frank
