On my 'Bird, the connector in the vacum lines at the rear of the inlet manifold looks a bit perished. Its the one that sits right at the back passenger side of the inlet. It has a vacum hoses join into it from each side, and appears to go straight into the manifold. According to Rockauto its and Emission Tee - Doorman part no. 47072, and it doesn't look like there's a thread on it or anything.
Can anyone tell me whether it is just a push fit into the manifold, or is there some kind of screw fixing arrangement?
I know the obvious thing to do is just to try and pull it out and have a look, but if I break it, I can't just go down to the Ford stealership and get another one over here in the UK.
yea it's a push on or pull off type..
So the side tubes push in, and then the T pushes into the manifold? Looks a bit awkward to get to, but if no tools are needed maybe its not so bad.
I have a slight misfire on light throttle at the mo, and was hoping that that will fix it (as I've tried all the expensive stuff!).
yea thats it..
