Did a search, and found nothing, What is the life of the upper and lower balljoints? How can you tell if they are bad?
Confirmed V6 Nut
From experience you hear a rubber slowly slipping on metal sound. You may feel the front tires not riding flat on the tread after the turn. If you really let the ball joint go, the wheel collapses into the fender well.
hmm, would it make a sound, if i bounced the front end of the car up and down? like putting pressure on it?
I'm just over 100k on mine. The upper ball joint on the driver side is damaged and making noise. I don't see anything on the passengers side but I'm going to replace both.
Refrigerator Raider Hater
I'd say 75K to 100K is the normal life expectancy of a balljoint. I've replaced 7 on three of my birds.
