1 - 11 of 11 Posts
how much torque do need on hub retainer bolt? for front hubs trying to get my braks back together. Thanks
Are you talking about the large 36mm nut at the center of the wheel hubs? If so, 188-254 ft-lbs.
seeming tight and actually being tight to the right spec are two different things.
I don't know about you but I wouldn't want that coming loose while I was driving because I THOUGHT it semed tight enough.
I tightened mine to 250ft-lbs.
250 ft-lbs is that the factory spec? When I pulled the dust cap off I expected a carter pin of some sort but there was only a bolt with a racer washer attached to it. That alone seemed scary to me.
What's the point in asking a question if you're not going to believe the answer?
An important note:
Install new front axle wheel hub retainer and tighten to 188-254 lb-ft.
The retainer is not reusable.
1 - 11 of 11 Posts
