1 - 20 of 31 Posts
My car pings, rattles, pre-detonates, etc. when I stomp on the throttle on the highway, or around town.
In old cars, this is caused by the timing being too far advanced. I had a `69 Torino GT with the 351W 4bbl. It had 10.7:1 compression, and I had to carefully check the timing when using lower octane fuel due to the pinging.
However, with my Cougar, I have no idea how to retard the timing. I also don't want to run premium in it since I will be using it for commuting 120 miles a day and the extra cost will really add up.
I think I've heard that some engines with higher mileage will develop the pinging due to carbon build up in the combustion chamber, which creates hot spots that can ignite the air/fuel mixture before its suppose to.
Anyone heard of that with the 4.6?
Any other ideas how to fix this? Could my free-flowing intake and filter contribute to the problem by leaning out the mixture?
Discussion Starter #2
Duh...
I did a search AFTER I posted and found plenty of good info.
I'll try the SeaFoam treatment, and clean the MAF to see if that helps.
Sorry for the unnecessary thread:(
you can change you timing by using either a timing adjuster that bolts to the crank pulley, or via a tune/chip/programmer..
Refrigerator Raider Hater
You can also pull the octane plug.
timing adjusters on the crank are bad because they trick the computer.
I have the same pinging under higher RPM load such as full throttle runs up to 80+ MPH. I have been reluctant to try carbon removal stuff as I have over 170 K miles on my 96 and can't afford potential damage to my engine. I have a 100 mile r/t to work each day (from New River to Mesa, AZ) and have been just running premium fuel to help out with the pinging. I am very interested in your results with the Seafoam before I try it. THANKS !!!
John
96 LX 4.6
Mods: Pure stock except for a K&N filter.
(Been running Castrol Synthetic 5W50 since 46 K miles)
SuperNewbie
John
96 LX 4.6
Seafoam wont hurt your engine. Just helps clean it up, and its provides a few minutes of smokey entertainment too:D
I've been seafoaming mine every oil change, (the day before the oil change) and am going to keep doing it until it quits helping; I have 210k on this one...
simply gotta get those combustion chambers clean.....dropping the timing on a bone-stock 4.6 is just a bandaid fix for an underlying problem.....you'll lose power when you drop timing, so you can also expect a slighty reduction in fuel economy
Well, I did the Seafoam routine and got a lot of smoke, seems to run a little better, but the pinging didn't go away.
It's fine when I'm down in Phoenix, but when I'm home up in Prescott, at 5000' above sea level, it pings really bad.
Coming up the mountain to go home is limited to 70 mph since any time the tranny shifts down, I get a bunch of pinging:rolleyes:.
I drove my wife's car to work the other day, and it did the same thing.
It's a 2001 Mercury GM with the 4.6 and 70k miles on it.
Both cars were purchased new at, and spent most of their lives at, low altitudes.
:confused::confused::confused:
Silly thought, but have you cleared the computer, to let it relearn the mix and stuff while at the higher altitude?
Pull the eec fuse in the underhood fusebox (#15?), and try to start the car, which won't start, and then put it back, and everything's clear...
I'd say 5000 feet is probably outside the normal adjustment range...
colder plugs can sometimes help too. i used to have a toyota that pinged like crazy w/ bosch plugs but was perfect w/ the recommended NGK's, just a thought. If you're not using the recommended plugs, i'd try getting those and see what happens.
Mine pings at low RPM, High load. (like if I try to accelerate in town, and the car doesn't downshift). But I have PI heads, and an SCT tune. I do run it on 91 Octane. I mixed about 3 gal of 110 Octane in it and (of course that fixed theh problem for that tank). but I can't do that all the time.
I'll put new plugs in tomorrow and see if that helps, but I don't think the current ones are that bad.
Discussion Starter #15
I'll try changing plugs, cleaning the MAF, and resetting the computer. I always use NGK plugs, but I can't remember if I've changed the plugs in this car. With 6 vehicles, it's hard to keep track of what I've done:confused:.
Anybody know which fuse is the EEC one that Grog6 spoke of?
4th big blue square one on the passenger side of the black power distribution box in the engine bay
There is no cure for an engine that is burning oil. The oil stays burning in the cylinder. 94/95 engines were plagued by this problem.
Alan
Discussion Starter #18
I reset the computer.
I don't know what prompted the reply by DirtyDog regarding the burning of oil, but, ironically, I just noticed this today.
I use Mobil 1 10/30 full synthetic. I have no oil leaks and no smoke. After putting about 2k miles on this oil change, I checked the oil on Wednesday and was down 3 quarts!
I filled it up and then checked it again today. Down another quart!
Where is the oil going??
out the exhaust
It was promtped by the plague of my own engine and the many many I have worked on.
Alan
1 - 20 of 31 Posts
