Status
Not open for further replies.
1 - 1 of 2 Posts
What do you guys think is the top record in the time (how long you can do one) a burnout? Good guess. But you are nowhere close to it. Actually, one of the best I have heared of was 22 min 43 sec burnout (on street tires) before they permantly blew up. HOW did he do it?! Simple.
This is what he did, he went to the junkyards and got 2 windshield wiper
injectors (the pump and the resovoir) and drilled two holes in his rear fenders above the tires. He had the two resovoirs on his trunk with a 50/50 mix of bleach and water. He then ran the button into the cockpit right onto the wheel (you hold down to spray). This made it possable to make burnouts with lots of smoke, while cooling the tires down so a major amount of tread is saved. This made for fun driving also because with a spray during a turn you could do very controlled slides without revving the engine too high and using
a large amount of tread. And don't ever ask how easy donuts are, its
like doing them in the rain (but you don't lose traction on front like you do in the rain).
Basically this is a very inexpesive mod and it will actually save you
money (because we all know about going through 2 sets of rear tires though one summer :) This mod just has endless uses, plus you can put whatever solution you want in there (I don't know what 100% bleach would do the the lines but it would help in a burnout.
TurboBird
1 - 1 of 2 Posts
Status
