Not sure where I should post this but here it goes,
I want to fire up my s/c parts car to see how it runs but not sure how to go about it with the complete interior missing from it. I do have the computer that I can plug in but how do I bypass the rest of the in car wiring?
You have an EVTM? Run wiring to the ignition circuits of the PCM, CCRM, ect. IE everything related to the running of the engine. Make sure grounds are still grounded(the ground junctions for the engine are usually attached to the PCM harness, so that should be good) and temporarily jump the starter circuit to turn it over.
No EVTM. :(
Where is the CCRM located on a 90 s/c?
Need to make sure its still there. Then I guess search for wiring diagrams.
Is there a way to bypass the CCRM?
The previous owner apparently kept it from the parts car.
Ok, so I got ahold of a ccrm today since mine was missing. Does anyone have a pinout for a 90 s/c and maybe some tips of which pins need power to fire it?
