1 - 12 of 12 Posts
I have a 94 t-bird and I hit a curb pretty hard, or at least hard enought to bend the part of the front sub frame that holds the tie rod and now my alignement is of by about 5-10 degrees. would a sledge hammer be able to bend it back or am I going to have to take it to a body shop to put on a frame rack? any ideas would be welcome on how to bend this back without spending allot of money as it is now just a back up vehicle for me and I just need it for when I am doing work on my truck.
thanks
jason
I would say take it to a shop and have them pull it, I seriously doubt a sledge hammer is going to do anything.
Frame
Using a sledge hammer is going to cause you more damage than you have already. Let a body shop take care of it. They have the tools and if there is a problem, you can go back and get it fixed.
thanks all I guess I'll start checking with shops and see how much its going to cost to throw it on the rack
Try calling some of the smaller family owned shops. My son put my Sable into a ditch & I called around & found a guy who only charged $200 to re-aline the frame. I had gotten prices from $400 to $1600 for the same work.
Bent
Having worked in a body shop for two years (1968-1970) If there is damage to the sub frame there is surely damage to the unibody..............see a body shop.
Yeah, and if you get another subframe from a junkyard, you may find out that the bolt holes won't line up to install it if the unibody is bent.
What I was getting at is there is no point in trying to straighten the lower subframe. If the bolt holes are off a portapower would probably fix it but still you are dealing with massive reconstuction. I had a car here that had the subframe so bent the oil filter would never come out ,but we put another subframe right on it.
Alan
1 - 12 of 12 Posts
