1 - 16 of 16 Posts
I've never seen them before but I'd say at 1-1/4" thick they'd screw up your wheel offset.
Probably just best to pick out a set of rims from the Custom Wheel Shop or just go ahead and do the hubswap.
Just buy the proper hubs for the rear its very cheap to buy rear hubs and cheaper for front hubs
Well I do have a question about the hub swap. I'm under the impression that it is all a direct swap except the brakes and or rotors. So if I were to do it I would keep stock calipers. Which means that I would have the rotors redrilled. I was just curious as to how safe that was. At only 1/4 in difference, wouldn't the holes overlap?
Hub swap
:wavey:
Just do the hub swaps.
as stated most wheels still won't fit with the adapters.
You might as well get custom wheels now.:gapteeth:
irsmachining.com for the rears. even rotors if you want.:thumbsup:
front easy with any 2000 pony front hub & rotors.
I am still running factory front & rear calipers.
no adapters. I do how-ever run aftermarket steel racing wheels.:zdunno:
:wiggle:
I can say I am VERY HARD on my wheels & brakes!!
:zdevil:
Check out motorsport-tech.com. I am using their 3/4 inch wheel adapters on the rear with 2005 Mustang wheels. They fit good with no problems.
There's a write up on it in the Technical Articles (follow the articles link from the home page and then brouse through the different sections.) The Hub swap is in the suspension section.
Here's a direct link:
http://members.tccoa.com/dlf/Article.html
I've been reading through that. The frustrating part is looking for rear hubs. They all say "99-04" cobra. Even summit racing. 99 is 28 spline and 00-04s are 31 correct? But I'm sure just making a call would clear things up.
I'll try to get some pics on here as soon as possible. This week's work is crazy (Way before sunrise till after dark.) BTW, I did the sn95 hub swap on the front, and the clearance on the front is really close.
:wavey:
To use the Cobra hubs & rotors, you would need the adapters & 17"+ wheels
:crazy:
The outer hub is 28 spline.
1 - 16 of 16 Posts
