Hey guys,
I have a humming noise that sounds like it's coming from under the hood somewhere. If you give it some gas, it usually goes away. If you don't then it will stall out. It does it while driving (although it doesn't stall out) and it does it while stopped ( and stalls out). Any ideas?
It's held in place by two bolts. Take them out, unplug the wire connector, and fish it out. It's a PIA to get at, but it isn't the hardest of jobs. About the same as doing the oil filter.
Just follow the small dia. plastic tube that comes out of the intake tube, just in front of the throttle body. The other end of it is connected to the IAC
It is basically behind, and to the driver's side of, the elbow that the throttle body is bolted to.
