1 - 11 of 11 Posts
This is quite annoying...whenever i try to goose it off the line...it bogs a little until about 2500 rpm then it starts to pull. I cant burnout and it just doesnot throw me back in the seat like it used to. i lust put in new plugs...nothing is misfiring so i know the wires are ok and i havnt 'recharged' my K&N yet so i know it is probably not my MAF? I want my baby's bite back!
Get a J-mod shift kit. Then you will thrown back in your seat ;)
Cleaning MAF wires is free so you can always try that anyway.
-Shawn
ok i tried that and it helped very little...what else can i try?
A looser TC and 3.73 gears.....
Also those plats have 6 times the resistance of copper, I'd either switch to
coppers for that large a gap or reduce the gap on those plats.....
oh ok then...i thought it was just me that was having this problem...do you think that .056 is a good gap?
wouldnt .4 be an ok gap? or does that come to close
Personally i'd just put in a set of coppers. If you want try regapping your plats first at .056 and see how they perform, go for it if you prefer to keep them....
I always gap mine at .5, I think stock is .53.
I remember a long time ago Uncle J wrote a response to a plug question and said that if you NA you need to stick with the stock gap.
Or maybe it was on the chip manuel that I got. Either way I don't remember when, why it was written, but I remember what it said.
Cheers:cool:
The emissions tag under the hood.... always check there first .52 - .56 but depending on the gap tool... the nearest gap is .54 .
1 - 11 of 11 Posts
