i have a 95 4.6 and im having a problem with the check engine light. I had the codes read and they said it was an emissions problem more specific the EGR valve. he told me to clean it. would i be better of replacing it?
Do you know exactly what the code was?? The 94-95s are a bear to replace. There behind the motor by the firewall.
-Matt-
MAMN12 Posse Member
P0402? I think that's it....anyway...Excess EGR Flow? That's the one I had, and I was told to replace this sensor on the back of the engine. I asked another knowledgeable person and they said that as long as the car runs/idles fine don't worry about it. So I didn't...it was on for at least a year before I pulled the engine.
also guys my low coolant light in the information center will not go off what do i do about that i have checked it everyday and its levels are perfectly fine
Trumpeter Extraordinaire
A short test from the 1994 Service Manual:
Pinpoint Tests
PINPOINT TEST C: LOW COOLANT INDICATOR ON WHEN COOLANT IS NOT LOW
C1 MEASURE RESISTANCE
Disconnect Indicator Lamp Module from body harness.
Measure resistance between Circuit 794 (LB) on the harness connector and ground.
Is resistance less that 1000 ohms?
Yes
SERVICE or REPLACE wiring harness or connectors.
No
REPLACE ILM.
How clean is the sensor? You may want to check if there's any build-up on the sensor inside the reservoir.....(just a thought). My car experienced an erroneous Low Coolant a few years back. I decided to flush the coolant system, removed the reservoir, and cleaned it thoroughly, as there was some build-up in it. No more erroneous light.
my coolant light was staying on i ran some power flush through it and filled it to normal level and it turned off
