It will looks so cool on top of the intake.
To make this tech...is there any way to make sure that this is a 207/215 cam?
At least I can try again in the spring. :)
Hey now, don't knock the guy. He just hasn't read the Instructions yet. Luckily, i've got a copy
Are you serious? I need to put the cam in there. :eek:
That looks hard to do.
The car is almost all put back together....no place to put the cam except in the closet or set it on top of the intake. If the seller was honest I would have had it a month ago and in the car. :mad:
my cam sat for 9 months before it got installed. And it still sits, just inside an undriveable motor :)
But Im glad that buttfook actually gave you your cam.
-Thomas
edit: btw, petec is the man! (Pete from fordchip)
oh, and there should be some scribing on the cam somewhere at the front of back, drawn with a dremel bit. Should give the cam info. If it was sold to erik by Mik from RPM, then he should be able to tell you what the info means. And if there's nothing there, it's not Mik's cam.
-Thomas
Dim Bulb
Got chips?
