Check engine light will come on now and then. I can turn it off by flicking it, unless gas is low. It's nothing important, just annoying. I don't want to cut it cause I might forget about gas. Not sure if it's a lose wire, but don't think so.
Also, my side window won't go down using passenger switch, and locks won't work either. Window will go up though. All driver side switches work with everything. Pushed down on the window switch on pass. side, and voltmeter doesn't move. The handle's broke, so that might be why. Any sugg.?
Flicking the light...
Flicking your check engine light doe snot do a thing to correct the error. You will have to go to a shop and have the code checked to find out what is wrong.
Discussion Starter · #3 ·
Well, it doesn't go off when I flick it when I'm out of gas, so I think it's a short.
