1 - 20 of 31 Posts
· Registered
I got a new sender and mounted it towards the back and it still got bent! I dont understand what its hitting.. the motor should move enough to smash it down. I mounted it forward before and now towards the back.. could I have a weak motor mount or somthing?? here is a current picture of it
· Registered
Discussion Starter · #2 ·
i know its extremely nasty under there.. but the amount of **** ive had leak, lines blown off and such thats good lol
· Registered
your sway bar bushings could be weak
· Registered
what i did was put a 1.5'' straight fitting, then an elbow
· Registered
whoa, damn.....oops, forgot to resize the pic....and yes i know it's dirty, i'll clean it when i pull the engine
· 02 Explorer Pioneer
You guys who apologize for the underside of a car being dirty are funny. It means you USE it. I have always maintained that dirt adds to the sleeper image :)
· Registered
· Registered
Discussion Starter · #11 ·
thats it! the sway bar was hitting it when it hit the ground.. figured that out today duhh on my half.. thanks guys!
· Registered
heres mine...
· Registered
Tobey said:
I used a kit from Summit and some miscellaneous fittings to relocate the sending unit. It's now clamped to the passenger side coil pack. If the link doesn't work, search for part number SUM-G2960 on Summit's website.
http://store.summitracing.com/partd...925228+4294923437+4294846127+115&autoview=sku
you don't recall what fittings you need do you? the reason i ask is my car is my only car so i really don't wanna have to jack it up figure out what i need drop her back down and then go get the parts. if you don't remember its no biggie
· Registered
The only fitting I used that wasn't in the kit was a 90* elbow. I THINK it was a 1/8" NPT, male/male. I'm not 100% sure that is the right size; maybe someone can confirm.
· Registered
Discussion Starter · #19 ·
1 - 20 of 31 Posts
