1 - 10 of 10 Posts
· Registered
ok heres my problem. my sister gave her car a tune up and she has the spark plug wires all mives up does anyone have a drawing or diagram of what cylinder goes to each plug on the coil packs? thanks
· Registered
Sisters car, yours lists a 4.6, but you posted to the 3.8, talk about coil packs, I think we need a wee bit more information.
This covers a 94 with a 4.6...
· Registered
Discussion Starter · #3 ·
ohh man she doesent even have a bird, she has a buick skylark with the 3300 v6 in it,i know it isnt about t-birds so give it the boot if u want, but i really need help because i wanna get this done before dark, and i didntknow where else to post it
· Registered
Go to www.autozone.com, enter in real car info (YEAR, make, model, actual engine (3800, 3.1, ...) then go to the Specifications->Ignition (tune-up)->Firing Order and you might find it.
A 1994 with a 3.1 is:
Code:
For your 1994 Buick Skylark:
Firing Order
Firing order 1-2-3-4-5-6          __
                          front   |        | |5|
                                  |  2  1  | |2|
                            of    |        | |3|
                                  |  4  3  | |6|
                         vehicle  |        | |4|
                                  |  6  5  | |1|
distributorless ignition - coil assemblies to right
                           engine shown to left
· Premium Member
The firing orders for the 1993 Buick Century engines are:
3.3 Liter engine firing order is 1-6-5-4-3-2 on this engine the #1 cylinder is closest to the FRONT of the car and closest to the belt (passenger's side of the car) Put another way, it is front right corner of the engine when viewed from driver's seat.
All this information is from page 20-4 of the 1986-1993 Chilton's Auto Repair Manual.
· Premium Member
What is the firing order for a 1993 Buick Skylark 3.3L V6?
According to Haynes Manual for Buick, Pontiac and Olds, all V6s have the following timing order.
1-6-5-4-3-2
EDIT:
According to my info., the Buick v6 3.3 liter engine was available from 89 thru 93.
It appears the firing order is the same on all 3.3's for those years
· Registered
Discussion Starter · #8 ·
uhh..im confused, i dont know what number the cylinders are, i know the numbers on the coil pack i juss need to know how the cylinders go, im basicly lookin for a pic like the first post! thanks
1 - 10 of 10 Posts
