I started installing my new 02 maf, tube and airbox last night. I was using embalmer's instructions. I got everything in place and was about to begin the wire splicing when I realized I had a different harness than he used in the instructions -- mine has four colored wires and his has six white ones. I'm not sure what to do since I need to have this done and the chip installed and ready to go by Sunday. I could hook the harness up the maf, but I don't know what to do about the IAT. The tube I have doesn't have a bung for it and there aren't enough wires to splice it into the new harness.
Also, when I ordered my chip from Apten I told them I had an 03 maf (I don't know what I was thinking). Would that cause a problem since I have an 02?
Just use the factory IAT for now, there is a square hole in the fender that it fits into pretty snugly. I know a lot of people running like that for a while now with no problems.
Refrigerator Raider Hater
02 and 03 are the same.
just stick the IAC near the air inlet till you can get the correct pigtail.
Thanks, guys. I 'll do that.
I've been thinking about my options -- would I be able to get a '99 GT tube (I think those have the IAT bung) and use that with the 02 maf? I'm thinking that might be the better way to go so I won't have to splice any wires.
Embalmer's harness had 6 white wires because he had to add the wires for he IAT to the connector. You could pin two wires in in the two empty slots in the connector.
