It turns over like nothing is wrong (maybe a bit faster). I have good fuel pressure. I am going to check the power to each coil pac. But I don't know if that is it. I doubt my trouble shooting skills. So If any one has a sure fire way to fix my no firing car...HELP!
P.S. Can I get a ignition Module from a junk yard?
P.P. S. THe car has had a miss durring acceleration for about three weeks.
could you have blown a computer fuse... the car will crack but not fire it it computer fuse out or burnt up...
get under the hood and look at the number 15 fuse (think its 15)
if any of them are burnt out, replace them.
One of my coil packs went and it also had a missfir like that, but unlikly both would go at the same time. I replaced them both to save time while I was at it...
get the nice ones from
http://www.supercoupeperformance.com/
there are great, and you can open your gap a little.
MG
You rock MadGoat! I have a fuse that is bad! I had this problem about three years ago. I just forgot about it....Thanks agian Eric
Glad I could help!
Now get that birddy on the road!!!
MG
