I just got 94 Cougar with the 3.8. I have learned alot by reading through all these posts but I still have a stupid question. Is the IAC suppose to make constant clicking sounds at idle? Also, my fuse for the alternator charge gauge and the low fuel/coolant/wiper fluid and door ajar indicator panel keeps popping if i try to replace. It came with a popped 5amp fuse in it. Is this correct and are there any likely spots for a short?
Thanks for the answer...The IAC clicks at the solenoid. When I touch it, i can feel the click coming from it. To clarify...the solenoid is not suppose to make a clicking noise?
Pedal Faster
No clicking. Are you sure you're not talking about the EGR pressure transducer? Because I think that is prone to clicking a lot if it goes bad or there is a problem with the EGR circuit.
