1 - 2 of 2 Posts
Does anyone know where the IAC located at? My idle sometime jump up and down around 400 to 600 RPM in D gear at a full stop. Any inputs is appreciated.:confused:
it's located behind the throttle body......right behind the tps mounted on the right side of the throttle body, and attached to the intake manifold. it's cylindrical in shape, silver, and has a black circular "breather" cap on top of it. it also has a harness that has i believe two wires that's connected to it......
it's secured by 2 bolts and between the IAC and manifold is a paper gasket,.....make sure that :
a. you don't drop a bolt in the wrong place (this just sucks)
b. you don't rip the gasket (it is paper after all)
just clean that sucker w/ mineral spirits and see what happens.......some people say it's a pain in the butt to get to on 94-95's , but on my 94 it was cake. (maybe i was just patient that day)
p.s. how did you get that P/N/D/2/1 indicator in there?.......and the lighted headlight switch? (i saw the pics in your directory)......PM me!
1 - 2 of 2 Posts
